display related products
11 years 1 month ago #206361
-- Joomla version -- : Joomla! 3.4.1 Stable
-- PHP version -- : 5.3.29
I want to display related products.
I made a new module as explained here www.hikashop.com/support/documentation/i...ct-form.html#related
I added 2 related products to one product but now it is showing a ton of related products to all of my products. What goes wrong?
  • Thank you received: 14184
11 years 1 month ago #206394
Please provide a screenshot of the settings of your module (when you edit it via the menu Display>Content modules) so that we can see how you configured it.
Some of its settings must be wrong.
11 years 1 month ago #206416
The module is still unpublished in modules
11 years 1 month ago #206432
As I don't speak your language it's not easy to read, but I think that it comes from the "Synchronize with current item when possible" setting which should be turned on in your module.
Note that it is normal that the module is disabled in the Joomla modules manager.
The following user(s) said Thank You: dutchman68
11 years 1 month ago #206475
Yes that works... thanks
