Related Products add to cart button problem
  • Thank you received: 4
10 years 11 months ago #213556
-- url of the page with the problem -- : maus.development.kandytech.net/shop-online/mouse
-- Joomla version -- : 3.4.3
-- PHP version -- : 5.5.28
-- Browser(s) name and version -- : Mozilla Firefox 40.0.3
I'm using the Related products module.
The module is displaying "Choose option" instead of "add to cart button".I tried to fix this but couldn't find a way.
How can I replace the Choose Options with the Add to cart button.
I would greatly appreciate any help.
Dilum.
Last edit: 10 years 3 months ago by dilum_tharaka.
10 years 11 months ago #213599
I found a way to do this. :cheer:
Now I don't want the related products under the product, I want it to the right.
How can I do this?
Last edit: 10 years 11 months ago by dilum_tharaka.
10 years 11 months ago #213620
To do that you'll just have to unset your product module from the "Modules to display under the main area" option via "Hikashop->System->Configuration->Display", and directly use the "Position" option through your Joomla module configuration page to move your module.
The following user(s) said Thank You: dilum_tharaka
10 years 11 months ago #213675
Thank you Mohamed,
Very clear instructions. :)
10 years 3 months ago #238547
I know this is a old post, but didn't want to create a new one under same category. So I'm writing this here.
I'm using a content module to display the related products. It was working fine, but with latest hikashop update, my products are redirected to different product page. You can check this here: mausfish.com/shop-online/fly-mouse
I will also attach a screenshot for this: joxi.ru/l2ZnEXgh8W3jd2 (Hikashop related product module settings is also attached. )
What can I do to fix this?
Thanks,
Dilum
  • Thank you received: 14184
10 years 3 months ago #238552
The problem is probably that you didn't select your "shop online" menu item in the "menu" setting of your related products module. Please check that.
10 years 3 months ago #238621
Hello Nicolas , Thanks for replying.
Weird thing is that the shop online menu item s not visible. Tried few times but still it's not showing up.
joxi.ru/gmv6z85sxbEk9m Screenshot is attached.
10 years 3 months ago #238644
Could you give us screenshots of your "shop-online" menu settings ?
If you try to create a new "product listing" menu, is it visible in the module "menu" dropdown ?
10 years 3 months ago #238743
I'm using 'single article' menu type for shop online page, as I wanted to develop the shop online page separately. I can give you admin details if you want.
10 years 3 months ago #238763
Ok I see the problem.
You can't use the shop online menu item since it's not a HikaShop menu item.
So what you want to do instead is to enter the URL you want for the product in the "canonical URL" of each product and then turn on the "force canonical URLs on listings" setting of the HikaShop configuration. That will solve the problem.
10 years 3 months ago #238778
Thanks Nicolas it worked. :)
