Serach product problems
10 years 10 months ago #215794
-- url of the page with the problem -- : www.dsgbutiken.com/index.php/webshop
-- Joomla version -- : 3.4.4
-- PHP version -- : 5.5.28
I have a simple question.
I have added a search field and a button to be pressed after search string is entered in teh search field.
After that I get a list of all items that match the serach phrase, for example "Lamp" generates all lamps in the shop.
Now when clilcking one of those links it points to a non existing URL with a correct URL + /component/search/ in the end and this is making an error 404 Page not found.
So how can I get rid of the /component/search/ at the end of all URLs?
I have compared it to another site I have witrh HikaShop Business that works but can't find any oddities between them.
I would bve very happy if you solved this for me.
Best regards,
Micke
  • Thank you received: 14184
10 years 10 months ago #215801
That issue has already been fixed. Update to HikaShop 2.6.0 and that should be ok.
The following user(s) said Thank You: LAMF
10 years 10 months ago #215871
Thanks that did it!
