Product Itemid issue in product layout listing
10 years 10 months ago #216838
-- url of the page with the problem -- : steinerindustries1.com/index.php?option=...t=listing&Itemid=629
-- Joomla version -- : 3.4.3
In this URL steinerindustries1.com/index.php?option=...t=listing&Itemid=629
I display four products, but the third product has an incorrect Itemid... and it should be the same as the other three.
I probably have a setting set somewhere, but after looking for quite a while, I cannot seem to figure it out.
Can you help please?
Dennis
______________
Dennis Kmetz
  • Thank you received: 14184
10 years 10 months ago #216840
It comes from the "canonical URL" setting of that product. Empty it or modify it and it will work.
The following user(s) said Thank You: dkmetz@taylorbruce.com
10 years 10 months ago #217890
This worked perfectly for me... thanks!
______________
Dennis Kmetz
