[SOLVED] Badges not showing up on products
  • Thank you received: 26
10 years 7 months ago #225473
-- url of the page with the problem -- : www.devree.info/hikashop-menu-for-catego...-veegmachine-sws600g
-- Joomla version -- : 3.4.8
-- PHP version -- : 5.6
I'm struggling on this website to make the badges visible.
Got it working without any issue on my test site.
Any tips of what can be an issue with badges?
I've been walking through the manual to see if it's any of the obvious, but no luck yet.
Thanks for any inspiration to get this solved !
Last edit: 10 years 7 months ago by nico.van.leeuwen.
10 years 7 months ago #225500
There is maybe a restriction set on the badges of the production site.
Could you give us a screenshot of the badges settings ?
10 years 7 months ago #225564
Sure I can :
  • Thank you received: 14184
10 years 7 months ago #225580
You've configured the "quantity" field to 1, so the badge will only display if the product has a quantity of 1.
Wouldn't that be the problem ?
The following user(s) said Thank You: nico.van.leeuwen
10 years 7 months ago #225660
Yes, that was the problem !
Thank you for helping me out.
