Do not display related products
10 years 7 months ago #225480
-- HikaShop version -- : HikaShop version Business 2.4.0
-- Joomla version -- : Joomla version -- : 3.4.8
-- PHP version -- : 5.5.29
Do not display related products even if they are configured . Example product whith related category do noti display attach the image.
My shop calculates the costs for virtual products, how do I fix?
Also how can I disable the tags of the products so they will not appear in the front -and ? Attach the image.
Last edit: 10 years 7 months ago by Mohamed Thelji. Reason: removed back-end access for security purpose
10 years 7 months ago #225503
1. Where do you exactly want to display your product related products ? Note that you can do it by setting the "Modules to display under the main area" option to "Related products" via "Hikashop->System->Configuration->Display".
2. What do you exactly mean about it and how do you want to handle virtual products ?
3.The best solution will just be to unset the values of the "Tag" option of your product page, or to use some CSS custom code like :
#hikashop_product_tags_main {
    display: none;
www.hikashop.com/support/support/documen...the-display.html#css
