Different page layout per product
10 years 7 months ago #225599
-- url of the page with the problem -- : 185.25.22.156/petshop.gr/
-- Joomla version -- : 3.4.8
Hello and a Happy New Year.
On product's backend I see that there is the option to choose Page Layout one from the prebuilds Hikashop's layouts (Inherit, Default, Reversed, Tabular).
I already know how to override and customize them by my needs but I want to add a couple of new layouts e.g. MyLayout1, MyLayout2, etc so to easily select it from the product's backend.
  • Thank you received: 747
10 years 7 months ago #225613
You can create and use as many product page layouts as you want, just make sure the file names start with "show_". So, name them e.g. "show_mylayout1.php", "show_mylayout2.php". They will then be selectable in the dropdown.
The following user(s) said Thank You: xatzopou
10 years 7 months ago #225605
So in HikaShop > Display > Views, edit a product display view, for example "show_default" and then you will see that you can rename it: take.ms/0h0RF
So just rename the view, and save it. That way it will create a new product display view, and you will be able to select it from the product edition page.
Time to create page: 0.403 seconds
