Products quantities problem / product div problem
  • Hikashop Essential
10 years 6 months ago #228550
-- url of the page with the problem -- : www.namibiabooks.com/joomla/english-books/non-fiction
-- Joomla version -- : 3.4.8
-- PHP version -- : 5.5.31
-- Browser(s) name and version -- : Firefrox 43.0.4
Hi.
I have 2 issus on the page:
1. In the bottom modules the number of products in a category are shown twice. Why?
2. For some of the products shown, the hikashop_subcontainer seems to be too large in height. Here it works well: www.namibiabooks.com/joomla/english-book...ory-politics-culture .
Here there is too much height: www.namibiabooks.com/joomla/deutsche-bue...grafien-erinnerungen
I understand that the several containers are rendered to have the same height, which is great. But I think there's too much white space (about 70 px) under the Add to Cart button. I just can't figure out why.
Kind regards,
Sebastian
10 years 6 months ago #228553
Hello Sebastian,
You should check the value that you have set through the "Pane height" option through your product listing menu/module configuration pages. If you didn't set any value in it, note that you can also set a value for each product listing menu/module.
Note that another solution can be to directly use some CSS code : www.hikashop.com/support/support/documen...the-display.html#css
10 years 6 months ago #228656
Okay - Let me see. What about my second issue;
Sebastian
  • Thank you received: 14184
10 years 6 months ago #228663
Edit the file "listing_list" of the view "category" via the menu Display>Views and replace its content by:
<?php
if(empty($this->rows))
	return;
$pagination = $this->config->get('pagination','bottom');
if(in_array($pagination,array('top','both')) && $this->params->get('show_limit') && $this->pageInfo->elements->total > $this->pageInfo->limit->value) {
	$this->pagination->form = '_top';
	<form action="<?php echo hikashop_currentURL();?>" method="post" name="adminForm_<?php echo $this->params->get('main_div_name').$this->category_selected;?>_top">
		<div class="hikashop_subcategories_pagination hikashop_subcategories_pagination_top">
		<?php echo $this->pagination->getListFooter($this->params->get('limit')); ?>
		<span class="hikashop_results_counter"><?php echo $this->pagination->getResultsCounter(); ?></span>
		</div>
		<input type="hidden" name="filter_order_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->value; ?>" />
		<input type="hidden" name="filter_order_Dir_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->dir; ?>" />
		<?php echo JHTML::_('form.token'); ?>
	</form>
<?php } ?>
	<div class="hikashop_subcategories">
<?php
$in_hikashop_context = (JRequest::getString('option') == HIKASHOP_COMPONENT && in_array(JRequest::getString('ctrl','category'), array('category', 'product')));
$cid = 0;
$last_category_selected = 0;
if($in_hikashop_context) {
	if(JRequest::getString('ctrl','category') == 'product' && JRequest::getString('task','listing') == 'show') {
		$last_category_selected = (int)$app->getUserState(HIKASHOP_COMPONENT.'.last_category_selected', 0);
		$config =& hikashop_config();
		$pathway_sef_name = $config->get('pathway_sef_name', 'category_pathway');
		$cid = JRequest::getInt($pathway_sef_name, 0);
	} else {
		$cid = JRequest::getInt('cid', 0);
$only_if_products = $this->params->get('only_if_products', 0);
switch($this->params->get('child_display_type')){
	case 'nochild':
	default:
	<ul class="hikashop_category_list<?php echo $this->params->get('ul_class_name'); ?>">
<?php
		$width = 0;
		if((int)$this->params->get('columns', 0) > 0)
			$width = (int)(100 / (int)$this->params->get('columns'));
		if(empty($width))
			$width = '';
		else
			$width = 'style="width:' . (int)$width . '%;"';
		$found = 0;
			$found = $last_category_selected;
			foreach($this->rows as $row) {
				if($cid == $row->category_id) {
					$found = (int)$row->category_id;
					$app->setUserState(HIKASHOP_COMPONENT.'.last_category_selected', (int)$row->category_id);
					break;
			if($only_if_products && $row->number_of_products < 1)
				continue;
			$link = $this->getLink($row);
			$class = ($found == $row->category_id) ? ' current active' : '';
		<li class="hikashop_category_list_item<?php echo $class; ?>" <?php echo $width; ?>>
			<a href="<?php echo $link; ?>"><?php
				echo $row->category_name;
				if($this->params->get('number_of_products', 0)) {
					echo ' (' . $row->number_of_products . ')';
			?></a>
		</li>
<?php
	</ul>
<?php
		break;
	case 'allchildsexpand':
		if($this->params->get('ul_display_simplelist', 0)) {
<?php
			foreach($this->rows as $k => $row) {
					continue;
				$found = 0;
		<li class="hikashop_category_list_item<?php echo $class; ?>">
			?></a>
<?php
				// DISPLAY SUB CATEGORIES
				if(!empty($row->childs)) {
					$limit = $this->params->get('child_limit');
					$i = 0;
?>			<ul>
<?php
					foreach($row->childs as $child) {
						if($only_if_products && $child->number_of_products < 1)
							continue;
						if(!empty($limit) && $i >= $limit) {
							break;
						$i++;
						$link = $this->getLink($child);
						$class = ($found == $child->category_id) ? ' current active' : '';
						echo $child->category_name;
							echo ' (' . $child->number_of_products . ')';
					?></a>
				</li>
<?php
			</ul>
<?php
		</li>
<?php
	</ul>
<?php
		} else {
	<div id="category_panel_<?php echo $this->params->get('id');?>" class="pane-sliders">
<?php
					continue;
					$row->category_name .= ' (' . $row->number_of_products . ')';
				if(!$this->module || $this->params->get('links_on_main_categories')){
					$row->category_name = '<a href="' . $link . '">' . $row->category_name . '</a>';
		<div class="panel">
			<h4 class="jpane-toggler title" id="category_pane_<?php echo $k;?>" style="cursor:default;">
				<span><?php echo $row->category_name; ?></span>
			</h4>
			<div class="jpane-slider content">
<?php
					$found = '';
							if($cid == $child->category_id) {
								$found = (int)$child->category_id;
								$app->setUserState(HIKASHOP_COMPONENT.'.last_category_selected', (int)$child->category_id);
								break;
					$i = 0;
							continue;
							break;
						$i++;
						?></a>
					</li>
<?php
				} else {
					echo JText::_('HIKA_LISTING_LIST_EMPTY');
				</ul>
			</div>
		</div>
<?php
	</div>
<?php
		break;
	case 'allchilds':
		$found = -1;
		$sub_selected = -1;
			if(JRequest::getString('ctrl', 'category') == 'product' && JRequest::getString('task', 'listing') == 'show' && empty($cid)) {
				$database = JFactory::getDBO();
				$query = 'SELECT category_id FROM '.hikashop_table('product_category').' WHERE product_id = ' . (int)hikashop_getCID('product_id') . ' ORDER BY product_category_id ASC';
				$database->setQuery($query);
				$cid = $database->loadResult();
				if(empty($cid)) {
					$class = hikashop_get('class.product');
					$product = $class->get(hikashop_getCID('product_id'));
					if($product && $product->product_type == 'variant' && $product->product_parent_id) {
						$query = 'SELECT category_id FROM '.hikashop_table('product_category').' WHERE product_id = ' . (int)$product->product_parent_id . ' ORDER BY product_category_id ASC';
			$i = 0;
					continue;
				if((int)$row->category_id == $cid) {
					$found = $i;
					break;
						if($child->category_id == $cid) {
							$found = $i;
							$sub_selected = $row->category_id;
							break 2;
				$i++;
			if($found >= 0) {
				$app->setUserState(HIKASHOP_COMPONENT.'.last_category_selected', $found);
			} elseif(JRequest::getString('ctrl', 'category') != 'category' || JRequest::getString('task','listing') != 'listing') {
				$found = (int)$last_category_selected;
		} else {
			$cid = 0;
<?php
					continue;
				$class = ($cid == $row->category_id) ? ' current active' : '';
			?></a>
<?php
					$sub_selected = false;
					if($cid != $row->category_id) {
								$sub_selected = true;
								break;
					if($cid == $row->category_id || $sub_selected == $row->category_id) {
						$i = 0;
?>			<ul>
<?php
								continue;
								break;
							$i++;
					?></a>
				</li>
<?php
			</ul>
<?php
		</li>
<?php
	</ul>
<?php
		} else {
			jimport('joomla.html.pane');
			$this->tabs = hikashop_get('helper.sliders');
			$this->tabs->setOptions(array(
				'startOffset' => $found,
				'startTransition' => 0,
				'displayFirst' => 0
			echo $this->tabs->startPane('category_panel_'.$this->params->get('id'));
					continue;
				if( !$this->module || $this->params->get('links_on_main_categories') || empty($row->childs)) {
					$row->category_name = '<a href="'.$link.'">'.$row->category_name.'</a>';
				// Allow to open the slider of the currently displayed category
				$toOpen = false;
				// Get the category id for category listing
				$cid = hikashop_getCid();
				// Get categories from product page
				if(JRequest::getVar('ctrl','category') == 'product' && JRequest::getVar('task','listing') == 'show'){
					$productClass = hikashop_get('class.product');
					$cid = $productClass->getCategories(hikashop_getCid());
				// Get main category from product listing
				if(!HIKASHOP_J30){
					$menuClass = hikashop_get('class.menus');
					$menuData = $menuClass->get($this->params->get('itemid',0));
					if(@$menuData->hikashop_params['content_type']=='product' && isset($menuData->hikashop_params['selectparentlisting']))
						$cid = $menuData->hikashop_params['selectparentlisting'];
				}else{
					$menuItem = $app->getMenu()->getActive();
					$hkParams = $menuItem->params->get('hk_product',false);
					if(isset($hkParams->category))
						$cid = $hkParams->category;
				if(!is_array($cid))
					$cid = array($cid);
				if(in_array($row->category_id,$cid))
					$toOpen = true;
						if(in_array($child->category_id,$cid))
							$toOpen = true;
				echo $this->tabs->startPanel($row->category_name, 'category_pane_'.$k, !empty($row->childs), $toOpen);
<?php
							continue;
						$class = ($cid == $child->category_id) ? ' current active' : '';
				<a class="hikashop_category_list_item_link" href="<?php echo $link; ?>"><?php
				?></a>
			</li>
<?php
		</ul>
<?php
				} else {
				echo $this->tabs->endPanel();
			echo $this->tabs->endPane();
		break;
	</div>
<?php
if(in_array($pagination,array('bottom','both')) && $this->params->get('show_limit') && $this->pageInfo->elements->total > $this->pageInfo->limit->value) {
	$this->pagination->form = '_bottom';
	<form action="<?php echo hikashop_currentURL();?>" method="post" name="adminForm_<?php echo $this->params->get('main_div_name').$this->category_selected;?>_bottom">
		<div class="hikashop_subcategories_pagination hikashop_subcategories_pagination_bottom">
		</div>
	</form>
<?php }
That should fix the issue.
