Problem with product with its options
10 years 5 months ago #233807
-- Joomla version -- : 3.4.5
Hi.
I have a product that has 4 options.
By default, the value of the product is 0 € and then each option has its price.
As I can do so that nobody can choose a product until you have chosen one or more options.
  • Thank you received: 14184
10 years 5 months ago #233822
There is no option to do that.
You need to edit the file "quantity" of the view "product" via the menu Display>Views and add a custom javascript check at the beginning of the $this->ajax variable.
Time to create page: 0.692 seconds
