Product Comparison Problem
  • Thank you received: 11
10 years 4 months ago #234114
-- Joomla version -- : 3.5
-- PHP version -- : 5.4.45
How can we setup the comparison table to compare the spec that we want? do we need to make all these info in custom field?
example, we would like to compare the spec of laptop
cpu
ram
capacity
battery
graphic
size
os
if we enter all these in table form of description , it do not compare it at all
  • Thank you received: 14184
10 years 4 months ago #234131
Yes, you need to make the information into custom product fields.
