Product listing and Product page not working
10 years 4 months ago #235389
-- url of the page with the problem -- : barnetpcservices.com/new/index.php/compu...ackups-and-utilities
-- Joomla version -- : 3.5
-- PHP version -- : 5.6.15
-- Browser(s) name and version -- : Firefox 44.0.2
The product listing is showing only one column. I have set it up to display 3 columns. This used to work but stopped working just like that.
The product page is not displaying anything. This never worked.
I have two installation, one local and one online both have same issues.
Please help me out to solve these problems.
  • Thank you received: 14184
10 years 4 months ago #235407
1. The issue is that you turned on the "use bootstrap design" setting of the Hikashop configuration but it is only compatible with boostrap 2 while your template is only compatible with bootstrap 3.
Turn off that option, or apply this to have HikaShop support bootstrap 3 and that will solve the problem:
www.joostrap.com/support/tutorials-video...p3-super-easy-update
2. I don't know why this happens. It looks like a problem with the template. Could you try to switch to the default template of Joomla and see if you see the product page with it ? If so, I would recommend to contact your template provider. Otherwise, I guess we would have to check your website settings.
