Bug - product specification + product custom info
10 years 3 months ago #237945
-- Joomla version -- : 3.5.1
There is a bug, I think, at the product item page for the specifications of the product.
When both the product specifications and own product specification via custom product fields are published, the custom field publishes again the Specification H4 title.
See the html:
<div id="hikashop_tabs_div">
<ul id="product-tabs" class="hikashop_tabs_ul">
<li id="hikashop_show_tabular_description_li" class="" onclick="displayTab('hikashop_show_tabular_description');">Beschrijving</li>
<li id="hikashop_show_tabular_specification_li" class="hikashop_tabs_li_selected" onclick="displayTab('hikashop_show_tabular_specification');">Specificaties</li>
</ul>
<div id="hikashop_show_tabular_description" class="hikashop_tabs_content" style="display: none;">
<div id="hikashop_show_tabular_specification" class="hikashop_tabs_content" style="display: inherit;">
<dl class="hikashop_product_dimensions">
<div id="hikashop_product_custom_info_main" class="hikashop_product_custom_info_main">
<h4>Specificaties</h4>
<dl class="hikashop_product_custom_info">
<dt>
<dd>
</dl>
</div>
</div>
<input id="selected_tab" type="hidden" value="hikashop_show_tabular_specification" name="selected_tab">
</div>
Those lines:
I can make it disappear in the CSS by adding
#hikashop_product_custom_info_main h4  {
display:none;
but it should not be there in fact.
Last edit: 10 years 3 months ago by Osindelka.
  • Thank you received: 114
10 years 3 months ago #237969
I can confirm that I had to add such CSS too....
10 years 3 months ago #238047
It seems that you are using an old version of the view "product / show_tabular".
So you can either add a css property or do a backup of the view and remove the override.
Last edit: 10 years 3 months ago by Xavier.
The following user(s) said Thank You: Osindelka
10 years 3 months ago #239079
Okay, I see.
I noticed that some of the views don't have to be up to date as I use the Storefront template from Gavick with pre-installed Hika Shop. I installed the business version over it, but the views stayed old.
10 years 3 months ago #239095
It's normal that the views stayed old, that's because the template is doing view overrides, so when updating HikaShop if there is overrides we still use the overrides. But the original views are up to date ;)
10 years 3 months ago #239170
Yep, that's what I meant. :) The views in the template override
