script and style tags are not saving correctly
  • Thank you received: 7
8 years 2 days ago #238964
-- Joomla version -- : 3.5.1
-- PHP version -- : 5.5
I am trying to customize the views and whenever I save my changes the script and style tags get changed to <s-tyle> and <s-cript> and the code within these tags is printed directly to the browser.
The text-filters in joomla global configuration are set to no filter for administrator and superuser.
Please suggest how can I fix the issue.
Last edit: 8 years 2 days ago by Dibben.
8 years 1 day ago #239017
I found a new issue when I was editing checkout->address file. It has $onclick variable and after saving changes this variable gets converted to $on-click. Again a hyphen is being added.
Joomla editor is JCE and I have turned off text filtering in its settings.
Please help.
  • Thank you received: 13082
8 years 1 day ago #239020
It's done either by your text editor or a plugin on your website or a security system put in place by your hosting.
I've seen that problem before but I don't remember what was causing it exactly. But it's not coming from HikaShop, that's sure.
Try deactivating the plugins one by one to identify the plugin doing that if it comes from a plugin.
The following user(s) said Thank You: Dibben
8 years 16 hours ago #239152
Thank you so much. You were right. I have RS Firewall installed on my site and that was messing with the tags. I just added my IP to Whitelist in RS Firewall and it fixed the issue.
Last edit: 8 years 16 hours ago by Dibben.
