Different characteristic display for products
10 years 2 months ago #242031
-- HikaShop version -- : 3.6.1
-- Joomla version -- : 3.5.0
-- PHP version -- : 5.3.24
I have some products with characteristics where I would like them displayed as dropdowns with quantity ajax input and other product with characteristics where I would like them displayed as a list and have a global add to cart. How can I do this?
  • Thank you received: 14184
10 years 2 months ago #242066
You'll have to edit the "show" file of the view "product" via the menu Display>Views, and add at the begin custom code to force the type of display based on the product.
Forcing the type can by done like that:
$this->params->set('characteristic_display', 'list');
10 years 2 months ago #242333
How do I make sure that the quantity field on the product page is displayed as global on listings and ajax input on everything else?
10 years 2 months ago #242372
Set it to "ajax input" in the HikaShop configuration, and at the top of the product/show view file, add such code:
$this->config->set('show_quantity_field',2);
