Product Module -varform.appendChild is not a funct
  • Thank you received: 6
10 years 2 months ago #243622
Hi, I am getting a varform.appendChild is not a function with the products module when I click add to cart.
I use 'mootools disable' plugin if that can be an indicator.
Can you please help?
  • Thank you received: 14184
10 years 2 months ago #243627
This indicates a problem with the add to cart javascript not finding the form of the add to cart button.
Can you provide a link to the page with the issue ?
10 years 1 month ago #243727
Thanks for the tip Nicolas.
I updated my template override and it is back working normally.
I have the site for a little while and there might being some changes in the recent updates that needed to be ported to my template override which I did and it is all good now.
Time to create page: 0.041 seconds
