Related products position
10 years 1 month ago #243805
-- HikaShop version -- : HikaShop Business 2.6.3
-- Joomla version -- : 3.15
-- PHP version -- : 5.5.12
I want to put the related product module in the left position of the product page, instead of right under the description like shown in the hikashop demo. How should I achieve this?
Best Regards
10 years 1 month ago #243807
There are many ways to get this kind of display but it's up to your website structure.
Can you provide an Url link in order to see your website and be able to help you more precisely.
Awaiting news from you.
Last edit: 10 years 1 month ago by Philip.
10 years 1 month ago #243888
Hi, Philip,
Thanks for the prompt response.
Here is my url:
Home Page: www.ccfia.org.tw/LTShop3/
Products list: www.ccfia.org.tw/LTShop3/index.php/hikas...E-%E5%A0%85%E6%9E%9C
Product detail: www.ccfia.org.tw/LTShop3/index.php/hikas...8F%E9%85%B8%E8%BE%A3
Because the site is in Chinese, so I provide 3 url for home page, products list and product detail.
Thanks in advance
Best Regards
Scott
10 years 1 month ago #243922
I had a look on your website, and I think I have your solution.
Can you try to go on your module back end configuration, and reproduce the same Position configuration, with the same settings than this module, see on screenshot :
More precisely, follow this steps :
- Go to Extensions => Modules
- Find the Related product Module AND with another window your module with id = 89
- For both go to their back-end configuration
- In Module tab, look for Position option.
- For the module with id = 89, just note the position reference (here in this example "position-7"), and for your Related products select the same position AND save !
Hope this will fit your needs.
Time to create page: 0.317 seconds
