Problem With Display of Color Variants
10 years 1 month ago #245865
-- url of the page with the problem -- : drbensppc.com/index.php/en/hikashop-menu...product/test-product
-- Joomla version -- : 3.5.1 Stable
-- PHP version -- : 5.4.45
-- Browser(s) name and version -- : Firefox 43.0.3 on Fedora 23 MATE
I have a setting of product with two color variants.
I configured everything exactly according to the 272-hikashop-display-by-color.html manual.
I have colors in the Joomla media.
I have product Characteristics defined accordingly and my product has 2 variants with colors.
When the product is displayed, it shows the main image at the top and below, it shows both variants.
The color switching operation does indeed switch the product variant (as can be seen by the title), but it does not switch the images.
My understanding is that when I switch color, it should be linked with the image(s) of the variant which should be switched over in the main product image window. AND, there should only be one image window for the product. Not one for every variant.
Do I understand right?
What am I doing wrong?...
Thank you.
  • Thank you received: 14184
10 years 1 month ago #245869
That's what it is supposed to do. It seems that your problem comes from the magic zoom extension. Try deactivating it and see if that works properly.
The following user(s) said Thank You: bshomer
10 years 1 month ago #245967
Indeed, when Magic Zoom Plus is unpublished the feature works well!
1. I wrote the author asking for help
2. Just in case - do you have any suggestion for a 100% HS compatible product photo zoom extension?
10 years 1 month ago #245991
Unfortunately, we are unable to advice you a photo zoom plugin that won't mess up with variant color...
I can only invite you to find a plugin fully compatible with all HikaShop feature and test it by yourself.
Hope that Magic Zoom plugin creator can give you a solution...
Last edit: 10 years 1 month ago by Philip.
