Problem with customfields. Values not saved in DB
10 years 2 days ago #248004
Since a couple of months??? when I create a new custom field, the value the is not saved in de DB anymore when a customer buys an article and fills in the custom fields.
It doesn't matter if it is a text field or an dropdownbox.
Old customfields are still working.
Columns are created into the database.
has somebody seen this problem/issue?
10 years 2 days ago #248007
We don't have some customers that report this kind of issue related to Custom fields, I think...
But we need more elements to be able to help you to solve this.
Can you provide :
- Your HikaShop & Joomla version
- Custom fields screenshot configuration
And just for checking, does your new orders display Custom fields value ?
Do you try to process an order WITH Joomla Error Reporting set to Maximum, and then see a error report ?
After switching this option to Maximum, do you see some error message ?
If yes, what tells this error message ?
Awaiting news from you.
Last edit: 10 years 2 days ago by Philip.
Time to create page: 0.203 seconds
