Module in product page do not show in right place
9 years 11 months ago #248503
-- Joomla version -- : 3.6.2
-- PHP version -- : 5.5.9-1ubuntu4.5
-- Browser(s) name and version -- : Chrome Version 52.0.2743.116 m
I created a module to show product categories and an other to see the cart in the right part of my template. The template we use is "Joomla Solid Pro" from "JoomlaShine".
The module shows correctly in the category view and in the product list view. But when we get to the product detail page (the last page), the module does not show to the right anymore, but in the bottom of the product detail. See print screen.
Could you help us find the source of this problem please?
Thank you in advance.
  • Thank you received: 14184
9 years 11 months ago #248511
This looks like a problem with the layout override of the product page by your Joomla template.
Try switching to the default template of Joomla and it should display fine.
And try renaming the folder templates/YOUR_TEMPLATE/html/com_hikashop/product/ via FTP to deactivate all the overrides of the product view in your template, and it should display fine for your template.
So then, try renaming the files one by one in that folder to identify which one is causing the problem.
If the layout is fine with you with that file override deactivated, then that's it, otherwise, you'll have to contact your template provider for help.
The following user(s) said Thank You: mark.krump@tecnic.ca
9 years 11 months ago #248655
Thank you a million! :) Just renaming my template solved it! :)
Thank you again! Have a nice day.
Time to create page: 0.523 seconds
