Max product quantity for cart
9 years 11 months ago #248996
-- Joomla version -- : 3.5.1
-- PHP version -- : 5.3.29
Hi Guys
I saw in the shop that i can set a max quantity for each product.
But i have never set a max for any product.....there is everywhere a 0 in this field.
So why can the user only put max 30 pices of every product in the cart?
On every product are 30 pieces max, to put in cart.
Where is the max qantity for each product defined in hika?
Thanks and best wishes
Marsi
You have to be patient with me :P
Last edit: 9 years 11 months ago by Marsipulami.
  • Thank you received: 14184
9 years 11 months ago #248998
Wouldn't it be because you have configured some limits under the menu Products>Limits on your website ?
The following user(s) said Thank You: Marsipulami
9 years 11 months ago #249127
Hi Nicolas
Yes you're right.
Thanks and sorry
Best wishes
Marsipulami
