Inventory for products with variants
9 years 10 months ago #252795
-- Joomla version -- : 3.6.2
-- PHP version -- : 5.6.22
We have some products that have variants that we need to control inventory on. In this case, the variants are all based on size, but the limitation is that each product gets a patch sewn on to the product. We are not limited by the different sizes, we are limited by the number of patches we have to put on the product. It is important that we don't oversell since the patches are custom and cannot be easily obtained.
Would it work to have the variants have unlimited quantity and the parent/main product have a limit? Would each sale of a variant decrease the amount available on the parent/main product and stop selling all sizes once the parent/main product sells out?
  • Thank you received: 14184
9 years 10 months ago #252802
Yes, that's how the system is made to work.
The following user(s) said Thank You: BNRBranding
9 years 10 months ago #253175
nicolas wrote: Hi,
Perfect! I was hoping that would be the case.
Does that also mean that if we assign an inventory value to the parent product and some of the variants, selling anything that has a positive inventory value would cause a decrement in both the variant and the parent?
9 years 9 months ago #253181
Even if you set a quantity for both the variant and the main product, then the quantity will reduced for both.
