Related products: Unrelated products appear in the list
9 years 9 months ago #253731
I set some products as related products, but the related products module of the product page shows some products that are not relayted.
I can't find the reason. Please help!
  • Thank you received: 14184
9 years 9 months ago #253737
Please provide a screenshot of the settings of the product, a link to the product page and a screenshot of the settings of your related products module.
9 years 9 months ago #253803
Product page url:
http://ghabnegin.com/products/moulding/sizes/5cm-7cm-width/product/884-527-46hs-%D9%BE%D8%B1%D9%88%D9%81%DB%8C%D9%84-%D9%BE%DB%8C-%D9%88%DB%8C-%D8%B3%DB%8C
Screenshots are attached (The related products module is located at the left sidebar).
Last edit: 9 years 9 months ago by mohaghegh.
9 years 9 months ago #253813
In my previous message, I also asked a screenshot of the settings of your related products module. Could you provide that too please ? You can find them under the "hikashop options" tab when you edit that module via the Joomla modules manager.
9 years 9 months ago #253879
Sorry, it's now attached.
9 years 9 months ago #253916
The problem is not solved yet.
Is there a cache for products?
Also I see this error message in the related products module backend: "An error has occurred while fetching the JSON data: HTTP 404 status code."
Any ideas?
9 years 9 months ago #253939
In the settings of your module, you've configured the "relation" setting to "in the same category" instead of "related products". So the module will display the products in the same category are the current product, instead of displaying the related products of the current product.
The error "An error has occurred while fetching the JSON data: HTTP 404 status code." doesn't come from HikaShop so I don't know why you have it but I don't think it is related.
Also, make sure that you turn off the caching on your website or you might not see the change after you modify that setting.
The following user(s) said Thank You: mohaghegh
9 years 9 months ago #253958
Problem solved.
Thanks Nicolas
