Issues With Sorting Products By Custom Fields
9 years 9 months ago #254477
I have a custom field I need to sort by which is a number with a decimal. I am unable to get any products to display. See link below:
www.juicy.deals/hot-deals
  • Thank you received: 14184
9 years 9 months ago #254503
The sorting is done alphabetically by MySQL.
If you want to change that, you need to go in your MySQL, edit the table hikashop_product and change the type of the column corresponding to your custom field to a "decimal" instead of a text.
