Add to Cart puts different products in cart than one selected
  • Hikashop Business Hikashop Essential
9 years 9 months ago #254618
-- url of the page with the problem -- : mcveighparker.com/online-shop/product/clipex-eco-post
-- Joomla version -- : 3.6.4
-- PHP version -- : 5.6.27
-- Browser(s) name and version -- : Chrome Version 54
We have noticed a problem with our website, when you go through to the following page and put this item into your basket it comes up with a different product in the shopping basket:
This seems to happen on lots of different products.
  • Thank you received: 14184
9 years 9 months ago #254622
From what I can see, the product added is the one in the module "Products you might like" that you have on the right side of the product page.
Looking further into it, it seems to be linked with the javascript code of the add to cart button not working properly, maybe due to the jchoptimize extension you have which modifies the javascript code of HikaShop.
Try to deactivate it and see if that helps.
Otherwise, removing the add to cart button on the module on the right side would also be an easy alternative.
