display product without product options
  • Thank you received: 92
9 years 9 months ago #255047
-- Joomla version -- : 3.6.2
-- PHP version -- : 5.5
For Menu item edit ( see capture screen ) ; hikashop has in product option panel 4 choices : div , table , list , inherit table . Is there a way to use none of those choice and added a new option instead those 4 choices ! .
Regard's
Attachment not found
Last edit: 9 years 9 months ago by lionel75.
  • Thank you received: 14184
9 years 9 months ago #255080
There is no option for that. But you can always customize the file "listing" to call another layout than the one selected in the options of the menu item. If you're a developer it won't be a problem.
9 years 9 months ago #255105
Thank's
i discover the file myself but for newbies ( like me ) the word listing don't help .
The word listing mean the files locate at /component/com_hikashop/views/product/tmpl/listing_*_*.php
This file can be override using in joomla Component -> hikashop and then Display -> view and then select using the search functonnalities the active template ( protostar here ) , a view ( product) , the front end , the comoennt ( here hikashop) ,the views ? ( the product ) .
From this page no documentation is available to know what mean all the item under view ( link to module ? to component ? to menu ?)
If i refer to the first post and the capture screen of product listing , no link to documentation ( using the help button ) seem available since the button link to joomla documentation and there is no hikashop help button to know more about the hikashop tab call product options .
Could we have the hiearchy of php file call . The Display -> view give the list but we don't know ( guess) which item are parent of others !
here a capture screen of personnal documentation that try to do that . The hikashop documentation do that but i think with time some item are missing ( no rectangle around the item)
9 years 9 months ago #255107
No documentation ?
9 years 9 months ago #255226
HI
I know this page and it is the page i print to use as a spreadsheet ( really helpfull) . My post was about link to documentation from joomla frontend !
regard's
9 years 9 months ago #255260
I suppose that you're talking about the help button of the HikaShop view edition backend interface and not the Joomla frontend interface.
I've improved a bit the documentation and added a link to the customization tutorial.
Thank you for your feedback.
