View Fade - Buttons cart and wishes not work
  • Thank you received: 19
9 years 8 months ago #257694
-- HikaShop version -- : 2.6.4 - 3.0.0 beta
Hi in view of the product Fade buttons do not work for the cart and wishes.
9 years 8 months ago #257711
Can you give us more information about it through some screenshots for example ?
Thank you for your feedback !
9 years 8 months ago #257739
This is version 3.0.0 beta. When I click on the buttons will be redirected to the product instead of being added. I'm not modify anything at the moment waiting for the final version to do the template on it.
9 years 8 months ago #257817
The fade effect is a CSS trick which change the opacity of the image (with a CSS transition).
But even if the image have a 0 opacity (so transparent) ; the image is still "there".
So if you click, you will still click on the image and not on the buttons which are "under" the image.
It would require some modification in order to change the CSS rules and handle the hover on the parent div ; so it will change the opacity and maybe change other elements like the "z-index".
The idea is to change the "ordering" of the elements to make the button be above the image so they will receive the "click" event.
Time to create page: 0.189 seconds
