Multi level products search
9 years 8 months ago #257742
-- Joomla version -- : 3.5
-- PHP version -- : 5.5.12
I have 2 questions about products listing:
1. Our user require 3 levels category search as shown below for products listing.
Is there a module for this?
If no, could you recommend or provide some sample code ?
2. I have an array of product ids, how could I use it as data source, to show it in product listing?
Thanks in advance
Best regards
Best regards
  • Thank you received: 14184
9 years 8 months ago #257747
1. It's not possible with categories with the options available.
What you can do is to use instead three custom product fields of the type dropdown with all the possible values and then three filters applying on these fields with their dynamic display turned on.
To do it with categories instead of custom fields, it would require a custom module to be developed to display the dropdowns with a custom plugin implementing the onBeforeProductListingLoad trigger to set your condition on the query loading the products :
www.hikashop.com/support/documentation/6...reProductListingLoad
2. You could set your array of ids in the variable:
$_SESSION['hikashop_viewed_products']
If you have a module with the "recently viewed" option turned on, it will automatically use the ids.
Time to create page: 0.267 seconds
