Homepage categories links problem
9 years 8 months ago #257867
My homepage is a category listing with subcategories
In my main menu the categories url are :
url.com/category/category-level-1/category-level2
In the component the urls are in 404 for subcategories :
url.com/category/category-level-2
Do i miss something in the settings ?
Jonas
  • Thank you received: 14184
9 years 8 months ago #257873
Enter the URL you want in the "canonical URL" field of your categories and set the "Force canonical URLs on listings" setting to "Use canonical URL if specified" in the HikaShop configuration.
That way, you'll have the url.com/category/category-level-1/category-level2 link you want used for the category links regardless from where you access them.
It will also improve your SEO.
