Problems in product description
9 years 7 months ago #258643
-- Joomla version -- : 3.6.5
-- PHP version -- : 5.6.27
Hello.
I am using editor TinyMCE.
In Hika Shop product description appears the code with code "font size" mixed with the text. (See attached image)
In website, the description appears normal.
I hope can you help me.
Kind regards.
9 years 7 months ago #258644
I am afraid that it is related to TinyMCE and the content you put in the product description.
Please take a look at your product page with another editor (none, codemiror) so you can change that your HTML is valid for either TinyMCE and a browser.
9 years 7 months ago #258710
Hello.
I did the test with jce editor, but the problem persists.
Regards.
  • Thank you received: 14183
9 years 7 months ago #258723
It's actually normal.
Here is a list of all the tags available in HTML:
www.w3schools.com/TagS/
As you can see, there is no "size" tag.
So the editors do not handle them as normal HTML and display them in the backend.
And for the frontend, the browser which interprets the HTML tags on the page is skipping them as they are invalid and thus you don't see them.
