Problem with mobile...
9 years 7 months ago #258830
-- HikaShop version -- : 3.6.4
-- Joomla version -- : 3.6.5
-- PHP version -- : 3.6
I attach 2 captures of my mobile.
1. How can I solve that there is not so much space between the photo and the name, please.
2. I need everything to be centered please.
Thank so much for your help.
Last edit: 9 years 7 months ago by rober1903.
  • Thank you received: 14183
9 years 7 months ago #258851
Try turning on the "use bootstrap design" setting of the HikaShop configuration.
It should already help make your listings responsive.
9 years 7 months ago #258886
Hi.
I don´t know where I must change this.
Thanks!!!
9 years 7 months ago #258888
As I said, it's in the HikaShop configuration page. It's under the Display tab:
www.hikashop.com/support/documentation/5...html#display_general
9 years 7 months ago #258983
For the movile it works perfectly. What should I do to center the button and the amount?But in the computer is seen in column.
How can I solve this, please?
I'll send you attachment of the configuration.
Thanks so much !!!
Regards !!
9 years 7 months ago #258986
I don't see what you're talking about on the link you provided before.
Could you provide a link where we can see the issues you're talking about ?
9 years 7 months ago #259037
The link is: adevaehijos.com
9 years 7 months ago #259065
Your Joomla template is missing the Bootstrap CSS.
You'll have to add it to it so that ht can display properly:
www.inmotionhosting.com/support/edu/joom...mplate/add-bootstrap
For the quantity input field not being aligned, you can remove that CSS:
.hikashop_product_quantity_input_div_default {
vertical-align: middle;
in the HikaShop frontend CSS in the Display tab of the HikaShop configuration.
9 years 7 months ago #259159
I added bootstrap to the template. (new.adevaehijos.com).
In mobile is perfect but in pc version the categories and products in column 1. I want to see in 3 colmuns.
9 years 7 months ago #259160
I'm afraid that there is no Bootstrap 2 in your template.
In any case, the usage of HikaShop 3 should fix all that kind of problem because it includes his own responsive grid system.
Time to create page: 0.879 seconds
