Create Product sets with multiple products
  • Thank you received: 13
9 years 7 months ago #259335
-- Joomla version -- : 3.6.5
-- PHP version -- : 5.5
Hello!
I have searched the forum and i found some topics about "bundle" but i think i need more help!
I want to create a "built your own set" situation so the user will be able to select among multiple products to create a set etc.
Is there a way to achive this?
Thank you in advance
9 years 7 months ago #259339
Currently, the nearest thing is the product options :
demo.hikashop.com/index.php/en/hikashop/...ct-page/with-options
9 years 7 months ago #259406
Hi Jerome,
yes i tried that. One question, the "product set" will include products from multiple categories, so i think it would be helpfull for the user if i could display the category's title above each option. Is this possible?
Thank you
  • Thank you received: 14182
9 years 7 months ago #259413
There is no option for that but anything is possible with customization.
You would have to edit the file "option" via the menu Display>Views and add custom code to load the category data from the hikashop_product_category and hikashop_category tables and then display it the way you want.
9 years 7 months ago #259566
Hi nicolas,
i see what you are saying, maybe you could give me an example?
Thank you again
9 years 7 months ago #259580
Something like that:
$db = JFactory::getDBO();
$db->setQuery('SELECT * FROM #__hikashop_product_category as pc LEFT JOIN #__hikashop_category as c ON pc.category_id = c.category_id WHERE pc.product_id=' . $product_id);
$category = $db->loadObject();
echo $category->category_name;
9 years 7 months ago #259645
Hi nicolas,
thank you for your help really but i'm gonna need a little bit more :)
Where should i add this code inside option view file?
I tried but i'm not very familiar with this so...
Thank you so much again
9 years 7 months ago #259650
Please understand that this is user support, not custom development.
Your subscription is even expired and I've already given you most of the code to do it.
You can't expect us to work for you for free.
Time to create page: 0.095 seconds
