issue on vote and comment settings
9 years 7 months ago #259720
-- Joomla version -- : 3.4.5
-- PHP version -- : 5.5
hi
im testing a new template a got for hikashop and hikamarket as well.
my issue is that if i set vote and comment to registered or bought my template for show_tabular gets messed up.
this is the setting
can you give me an idea on what to look at?
thanks
  • Thank you received: 14182
9 years 7 months ago #259743
First, you need to check if the problem comes from the template or HikaShop.
If you rename the folder templates/YOUR_TEMPLATE/html/com_hikashop to something else via FTP, does it display properly ?
If it does, then there is a problem with the view overrides of your template.
You can try to rename the files one by one in the folders templates/YOUR_TEMPLATE/html/com_hikashop/product and templates/YOUR_TEMPLATE/html/com_hikashop/vote in order to identify the file with the issue.
Time to create page: 0.241 seconds
