question about product code after copy a product
9 years 6 months ago #261147
-- Joomla version -- : 3.6.5
Hello
I have a question about product code after copy a product
When i creat a new product and I left the product code empty after saving the system makes the product code, it is ok,
But If I copy a product when I open that I find the old product code+ copy+number, now If I delete that product code and I save the product the system doesn't make the new product code and it is empty.
It is normal??
Frank
  • Thank you received: 14182
9 years 6 months ago #261183
Yes. The product code is not required anymore. It is filled automatically based on the product name when the product is created if you don't provide it.
But you can leave it empty. However, the database still require each product_code to be unique.
9 years 6 months ago #261245
ok thanks
