Wrong Itemid in Order Management(backend) for show product
  • Thank you received: 11
9 years 5 months ago #264191
-- Joomla version -- : 3.6.1
-- PHP version -- : 5.4.45
Dear
We face this problem
option=com_hikashop&ctrl=product&task=show&cid=8024&tmpl=component&Itemid=890
item 890 is currently a login/registration page and thus it cause a error
an itemid was added wrongly, we can not find a place to change it from configuration, how can we define this itemid for backend product link in the order editing page?
  • Thank you received: 14182
9 years 5 months ago #264220
There is no option for that.
You'll have to change the line:
<a onclick="return window.orderMgr.showProduct(this);" href="<?php echo hikashop_frontendLink('index.php?option=com_hikashop&ctrl=product&task=show&cid='.$product->product_id,true); ?>"><?php
in the file "show_products" in the menu Display>Views in order to add the Itemid parameter you want. Since there isn't any defined by default, HikaShop automatically attributes one from the frontend.
