How to make Navigation between products clearer
9 years 2 months ago #271090
-- url of the page with the problem -- : transmetra.imaufbau.ch/produkt/druckkraf.../category_pathway-87
-- Joomla version -- : 3.7.2
-- PHP version -- : 7.01
As you can see in the image, the arrows for previous/next products are so tiny, they are almost invisible.
I'd like to make them larger. Can I do this?
David
  • Thank you received: 14182
9 years 2 months ago #271091
Sure.
If you look at these arrows with your browser explorer, you'll find the CSS code which defines them:
monosnap.com/file/xtm5J8DZJb7YUbtYIKfsYj90yPppNx
As you can see, it's in the frontend CSS file of HikaShop.
Edit it via the HikaShop configuration and change the width, height and the background image and you'll be able to have the size you want.
The following user(s) said Thank You: iamalive
9 years 2 months ago #271160
Hi Nicolas
Thanks - it's a bit of a struggle finding the richt combination of CSS and creating the relevant image, but I've managed to do it (I think)
David
Last edit: 9 years 2 months ago by iamalive.
Time to create page: 0.169 seconds
