Change Way Products Are Displayed on the Products Page
9 years 1 day ago #276266
I am very new to Hikashop (2 days). I would like to change the way my products are displayed. I have attached an image of the way they are presented now (product-before) and the way that I would like them to appear (product-after). I would also like to style the product title (font-family, font-size and color) along with price line. I will be eternally grateful to all for their help. Thanks Everyone.
  • Thank you received: 14182
9 years 1 day ago #276273
First, when you edit your menu item via the Joomla menus manager, under the "products options" tab you have settings to customize the display of the listing. There, you'll find an option to display only the taxed price and not both.
Then, if you want to change the order of the elements and place the name before the image instead of after, you can edit the file "listing_img_title" of the view "product" via the menu Display>Views and swap the different blocks of code.
And lastly, if you want to change the size/color of a text, you can add custom CSS to HikaShop.
Regarding these 2 last points, I invite you to read this tutorial which explains how to customize the CSS of HikaShop, and how to customize the view files of HikaShop:
9 years 23 hours ago #276291
Thanks. I will work on implementing your solutions.
