hikashop_product_left_part and hikashop_product_right_part overlay each other
8 years 11 months ago #278611
Dear users,
the hikashop_product_left_part and hikashop_product_right_part overlays each other inappropriately.
  • the "Add to cart" is placed on the Image
  • the increase and decrease signs to the item count are in larger distance to the count
Using hkc-md-8 for the hikashop_product_left_part and hkc-md-2 for the hikashop_product_right_part gives much better visibility for the two sides, the image and the count options. Where can I set the hkc-md-X parameters / variables permanently? I could not find any settings for those widths in the back/end of the HikaShop. Thank you
  • Thank you received: 14182
8 years 11 months ago #278632
There are no settings to change the hkc-md-X of the divs.
You can edit the view of the product page in order to change them:
Or you can also add some CSS with !important to override the default CSS for the width of these elements.
Or you can also reduce the size of the main image in the "Images" section of the HikaShop configuration so that it fits in the space available for the main image of the product.
8 years 11 months ago #278680
Thank you, nicolas!
I changed the product / show_default.php to the extend I announced earlier.
