Add to cart popup doesn't work on product page
8 years 10 months ago #279161
After Hikashop update, when a product is added to cart, the add to cart pop-up doesn't display when the user is logged inside the website.
The pop-up is displaying only when the user is not logged inside the website.
thanks!
  • Thank you received: 14181
8 years 10 months ago #279164
Please provide a link to the shop, a test user account credentials and instructions to reproduce the issue.
8 years 10 months ago #279267
I've sent an email with all the details. I've added a link to this post also.
thank you!
8 years 10 months ago #279269
I'm not able to reproduce the problem: monosnap.com/file/ypAz34IxAnA6dFtlz1iF1W1OMg4oBT
I'm logged in with the credentials you provided, I add a product to the cart, and the popup displays as expected.
8 years 10 months ago #279348
can you please try to add a couple of products to cart?
I've tested on all browsers. The issue is the same. Once I'm logged inside the website the pop-up doesn't display.
thanks!
8 years 10 months ago #279353
I've tried with other products and it worked fine too:
monosnap.com/file/ucJstZMutJSOyrDfTraJs5dHfBKPGx
monosnap.com/file/2ptvy4PPnqT3EmdFRLJ4g7HDUutBRQ
monosnap.com/file/NK05puH6VZse0nqKoYdIbI42RLyjFL
Maybe you have a problem with the data of the carts on your account. Try to clear them in your backend and try again.
8 years 10 months ago #279475
I've logged inside the account that I've created for you and the pop-up works correctly.
I've logged in other website accounts and for some it works and for other it doesn't.
Can you please let me know where exactly I can clear the carts data?
thank you!
8 years 10 months ago #279476
Go in the menu Customers>Carts and you can see all the carts there and delete them.
8 years 10 months ago #280081
I've removed all carts data, but the problem persist.
I've send via your contact form logins to my account so you can check the issue.
thank you!
8 years 10 months ago #280093
With your account, when I test, I get some XML back from the server before the normal response from HikaShop:
monosnap.com/file/anz6An7DW4eje0A4j4ToOctNU4KXqo
Because of that, the javascript of the add to cart system doesn't know what to do and thus it doesn't display anything.
It's apparently some debug data from a shipping plugin commented out but still displayed on the pages.
I would recommend to remove that debug data and it should work just fine for you too.
I guess that you must have added it to be displayed only for your user account, or only for some addresses, or something like that which is why I didn't had the issue with the other user account.
8 years 10 months ago #280181
it looks that the problem came from one of the shipping plugins. The debug mode was enabled. I've disabled it and now everything works correctly.
thanks!
