Products display
8 years 10 months ago #279839
I have added serveral products in Hikashop,
but I d'ont know how to make them on my website,
the template is Protostar, I know how to do in Virtuemart,
but as I need not to parametre the menu in Hikashop, so I d'ont know how to do,
please kindly help me !
  • Thank you received: 14181
8 years 10 months ago #279864
When you install HikaShop, it automatically adds a menu item configured to access your products. By default it's in the "HikaShop default menus" group of menus in your Joomla menu manager.
So all you need to do is to edit it and move it to your main menu and you'll have an additional menu item in your main menu to access the webshop.
In fact, if you went through the HikaShop install wizard at the end of the installation of HikaShop, you can select to have it moved to your main menu automatically. Did you skip the install wizard page maybe ?
8 years 10 months ago #279926
yes, it's OK, thank you so much !
