Display problems
8 years 10 months ago #279983
-- url of the page with the problem -- : www.dreamlordpress.it
-- Joomla version -- : 3.8.1
-- PHP version -- : 7.0
Hi, I have two problems.
1) Some products generate a complete white page. It's on two istances of the same product, so I think something maybe in the product options crashes the display. Other products work seamlessly.
www.dreamlordpress.it/acquista/negozio/p...trumenti-del-sistema
www.dreamlordpress.it/acquista/negozio/p...enti-del-sistema-pdf
2) In the "prodotti per categoria" sidebar, selecting one of the categories spoils the title of others.
I find something like this in the generated html: <h4> <a class=accordion-toggle data-toggle=collapse data-parent=#category_panel_103 href=#category_pane_1> </a><a href="/acquista/negozio/product/listing/<strong class="keyword">fate</strong>-pdf">Fate (PDF) </a> </h4>
You see the wrong <strong> tag.
Dreamlord Press
Roleplaying Games in the new era
8 years 10 months ago #279985
1 - Full blank page = Please check your PHP error log.
(or force the display of PHP error message via your Joomla global configuration and the "error reporting" setting).
2 - There is no code in HikaShop to add a "strong" tag and I can't find nowhere a reference of " class=keyword" " ; so I think that you're using a third party (system) plugin which is modifying the content.
8 years 10 months ago #280008
Hi Jerome,
Thank you for your reply, you where obviously right: SEOBOSS was the plugin causing both the problems.
There is a setting in SEOBOSS that lets you automatically highlight the keywords inside the page with a <strong> tag, and it caused both the problems.
Disabling that feature solved it.
Thank you.
Dreamlord Press
