[SOLVED] display products for certain zipcode
  • Thank you received: 26
8 years 8 months ago #283625
-- Joomla version -- : 3.8.2
I've been searching the forum for a nice bit of inspiration to have the following :
The website has products from local suppliers all over the country.
A customer wants to buy products from a supplier that is near to him and types in his zipcode.
Now he should see only products from suppliers who aggreed to deliver to his zipcode.
I have found solutions that talk about filtering shipment methods for a certain zipcode but not yet the display of products for a certain zipcode.
Any tips / suggestions on an approach for this ?
Many thanks in advance.
Nico
Last edit: 8 years 8 months ago by nico.van.leeuwen. Reason: solved
  • Thank you received: 14181
8 years 8 months ago #283629
You could have a custom product field so that you can select the zip codes for each product, and then configure a filter on that custom field so that you could filter the products based on the zip code selected by the customer in the filter.
8 years 8 months ago #283852
That works great, thanks!
Nico
