nicolas wrote: Hi,
So it was displaying before ( you said it displayed two months ago
www.hikashop.com/forum/product-category-...uct-page.html#341665
) but now it doesn't show anywhere. What did you change in the settings of the module in these two months ?
Did you set the "menu assignment" to all the menu items ?
The settings of your screenshots look ok.
Is the "position 1" a position of your template ? Not another template ? Because if the position is not a valid one for your current template, then it won't display.
Also, how is the filter configured ? It's possible that the module is actually being displayed but the filter is not because it has nothing to display (for example, if you configured it to be based on a custom product field without any values). Could you maybe provide a screenshot of the settings of that filter ?
the problem was this "if you configured it to be based on a custom product field without any values"!
I configured the price field as the filter and use hikashop in "Catalogue mode" without any price, so the module won't display anything!
the mentioned issued solved, and now the name filter is displayed on the top position of the category, how can hide it from that position?
Thanks again
Thanks again my friend
