Problem with calculation of product price by "decimal" length
7 months 4 weeks ago #369772
-- url of the page with the problem -- : www.ravopleko.gr
-- HikaShop version -- : 6.1.1
-- Joomla version -- : 5.4.1
-- PHP version -- : 8.3
I'm using your solution for calculating product price by length.
See topics:
-https://www.hikashop.com/forum/product-category-display/898379-calculate-product-price-by-length.html
-https://www.hikashop.com/forum/product-category-display/898421-decimal-calculate-product-price-by-length.html
But at the cart the price is calculated wrong.
Please see the attached screenshot were I'm testing various possibilities (I removed any restrictions for testing purposes).
  • Thank you received: 14177
7 months 3 weeks ago #369773
I suppose you're using the plugin www.hikashop.com/marketplace/product/221...quantity-plugin.html
So, the probably is probably with your custom item field. The column name of the custom field must be exactly "ordered_length". Otherwise, it will be ignored by the plugin.
Alternatively, you can use the price calculations plugin:
www.hikashop.com/marketplace/product/148...ce-calculations.html
It has many advantages over the plugin you're using:
- you can have different fields for different products
- you can enter complex calculation formulas, not just price * value, and you can combine the value from different fields if necessary
- the plugin directly displays a "calculated price" on the product page when a field value is changed.
2 months 3 days ago #372226
you have to provide an updated version of the plugin:
I changed the code so that it works with the new Hikashop versions.
I don't know if it is 100% correct.
Best,
Yannis
<?php
jimport('joomla.plugin.plugin');
class plgSystemCustom_quantity extends JPlugin{
if(!function_exists('fid_custom_quantity_normalize_length')) {
	function fid_custom_quantity_normalize_length($value) {
		$value = trim((string) $value);
		$value = str_replace(',', '.', $value);
		return (float) $value;
if(!function_exists('hikashop_product_price_for_quantity_in_cart') && !function_exists('hikashop_product_price_for_quantity_in_order')) {
	function hikashop_product_price_for_quantity_in_cart(&$product){
	$currencyClass = hikashop_get('class.currency');
	$quantity = @$product->cart_product_quantity;
	$ordered_length = 1;
	if(!empty($product->ordered_length)){
		$ordered_length = fid_custom_quantity_normalize_length($product->ordered_length);
	$currencyClass->quantityPrices($product->prices, $quantity, $product->cart_product_total_quantity);
	if($ordered_length > 0 && $ordered_length != 1 && !empty($product->prices)) {
		foreach($product->prices as $k => $price) {
			if(isset($price->price_value)) {
				$product->prices[$k]->price_value = (float) $price->price_value * $ordered_length;
			if(isset($price->price_value_with_tax)) {
				$product->prices[$k]->price_value_with_tax = (float) $price->price_value_with_tax * $ordered_length;
	function hikashop_product_price_for_quantity_in_order(&$product){
		$quantity = $product->order_product_quantity;
			$quantity = $quantity * $ordered_length;
		$product->order_product_total_price_no_vat = $product->order_product_price * $quantity;
		$product->order_product_total_price = ($product->order_product_price + $product->order_product_tax) * $quantity;
Last edit: 2 months 3 days ago by nicolas.
2 months 3 days ago #372229
I've updated the plugin. Thanks for the feedback.
