Display product custom fields in different parts of product
  • Thank you received: 13
6 months 4 weeks ago #370360
-- HikaShop version -- : 6.3.0
-- Joomla version -- : 3.10.12
Hi!
I have 3 product custom fields displayed at the bottom part of the products.
Is it possible to display 2 of them in the right part and 1 in the bottom part?
Thank you
  • Thank you received: 14203
6 months 4 weeks ago #370363
There is no option to display product custom fields in different parts of the product page. However, with some view override, it is possible to do it with a bit of custom PHP. A developer will have no problem doing it. An AI should be able to help you with it too provided you give it access to the files in components/com_hikashop/views/product/tmpl/ and templates/YOUR_TEMPLATE/html/com_hikashop/product/
