Round problem for products when discounts
11 years 7 months ago #189930
-- url of the page with the problem -- : www.patrickguedj-paris.com/ventes-flash
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.5
I reinstalled my existing site with a Joomla 3 and a new template.
After performing all customizations and migrations for past users and commands, I would like to create a new product for a sale.
This product has a regular price of 350€ TTC and should be sold 129€ TTC
I created a discount category affected to the product and a Discount of 63.14%
Finally the product is displayed at 129.01 € TTC
Because of roundings in the products price HT or TTC, or in Discounts, I'm never able to have round prices for HT and TTC (350€ and 129€)
Could you please help me ?
  • Thank you received: 14210
11 years 7 months ago #189942
Did you try changing the option "round prices during calculations" in the HikaShop configuration ?
11 years 7 months ago #189999
Thanks Nicolas for answering.
If you mean Taxes / Round prices during calculations ?
of course I tested it and see no differences.
11 years 7 months ago #190002
Could you provide a screenshot of your discount options and a screenshot of your tax rule so that we know exactly how they are configured ?
11 years 7 months ago #190119
Thanks Nicolas
Last edit: 11 years 7 months ago by codewarrior.
11 years 7 months ago #190128
So, in that case, the solution is to increase the number of decimals of the discount percentage.
You can do that in two steps:
- First, run this SQL query in your MySQL database via your phpmyadmin:
ALTER TABLE `#__hikashop_discount` CHANGE `discount_percent_amount` `discount_percent_amount` DECIMAL( 10, 3 ) NOT NULL DEFAULT '0.00'
After replacing #__ by your table prefix.
- Change the percentage value of your discount from 63.14 to 63.143
Last edit: 11 years 7 months ago by nicolas.
The following user(s) said Thank You: codewarrior
11 years 7 months ago #190240
Thanks Nicolas, you're the best !
It works fine now.
Could it be an option in new versions ?
11 years 7 months ago #190315
From next version on, we'll have three decimals support in the discount percentage field for new installs.
You won't need to do anything.
Time to create page: 0.779 seconds
