Currency Module problem when place it in mainnav
11 years 5 months ago #196474
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.5.12
Dear sir
thanks for great product
I have a problem in making Currency module working , I use Module anywhere to place the hikashop Currency module in the main menu, the module shows and list of currencies shows, but if I select any currency it just do nothing, it do not switched to that currency
if I publish the module in any other position using Module anywhere it works, so its not module anywhere problem I think!
I published other modules in the same way (like cart module, filtering module, ..., all worked except the currency module
thanks
  • Thank you received: 14210
11 years 5 months ago #196515
I don't know why this happen but try to change the option "Do not use a form" of that module. It might help avoid the problem.
11 years 5 months ago #196534
hi
changing the "Do not use a form" to yes did not help
any thoughts?
11 years 5 months ago #196540
Ok, replace the whole content of the file modules/mod_hikashop_currency/tmpl/default.php by this code:
<div class="hikashop_currency_module" id="hikashop_currency_module_<?php echo $module->id; ?>">
<?php if(empty($mode_noform)) { ?>
	<form action="<?php echo hikashop_completeLink('currency&task=update'); ?>" method="post" name="hikashop_currency_form_<?php echo $module->id; ?>">
		<input type="hidden" name="return_url" value="<?php echo urlencode($redirectUrl); ?>" />
		<?php echo $currency->display('hikashopcurrency',hikashop_getCurrency(),'class="hikashopcurrency" onchange="document.hikashop_currency_form_'.$module->id.'.submit();"'); ?>
	</form>
<?php } else {
	echo $currency->display(null, hikashop_getCurrency(), 'class="hikashopcurrency" id="hikashopcurrency_'.$module->id.'" onchange="window.localPage.switchCurrency(this);"');
<script type="text/javascript">
if(!window.localPage) window.localPage = {};
window.localPage.switchCurrency = function(el) {
	var url = "<?php echo hikashop_completeLink('currency&task=update&hikashopcurrency={ID}'); ?>";
	url += ((url.indexOf("?") !== false) ? "?" : "&") + "return_url=<?php echo urlencode($redirectUrl); ?>";
	window.location = url.replace("{ID}", el.value);
</script>
<?php } ?>
</div>
and keep the "Do not use a form" option turned on and try again.
11 years 5 months ago #196564
Great Product with Great Support
it worked :woohoo:
