Problems changing order of products
11 years 2 months ago #205485
-- url of the page with the problem -- : www.deziroo.com
-- HikaShop version -- : new
-- Joomla version -- : 3.3.6
I have the Product listing for ordering field set to ordering, so I can choose the order of the products, but its not letting me change them. I tried setting all the product areas I see the ordering field to order.
  • Thank you received: 747
11 years 2 months ago #205514
In the backend list of products, change "All sub elements" to "Direct sub elements". Then you can order the products as you like.
11 years 2 months ago #205523
It already is on Direct sub elements
11 years 2 months ago #205534
Sorry, should have specified more exactly:
The backend list as in your screenshot "Screen_Shot_2015-06-19_at_10_02_27_PM.png". That's the list you get under -> Products -> Products. See the dropdown in the upper right corner there.
The following user(s) said Thank You: deziroo
