Downloadable AND shippable products on same site
  • Thank you received: 4
9 years 10 months ago #252356
In the main configuration Hikashop requires to choose either downloadable products or hard copy products.
Is it possible to have both?
I have a client who sells their photos both in digital and in printed format.
thanks
Giedre
  • Thank you received: 14203
9 years 10 months ago #252359
There is no setting in the HikaShop configuration which requires to choose either downloadable products or hard copy products.
It's possible to have both, that's not a problem.
There is a setting called "force shipping regardless of weight" which will force the customer to select a shipping address and shipping method even if the products in the cart don't have a weight. But if it's turned off, the shipping interface will be on or off automatically on the checkout based on the weight in the products.
9 years 10 months ago #252612
Thank you, Nicolas.
I think i got confused because of the setting in the configuration screens.
Kind regards,
Giedre
