Difference btw Max Length and Size in custom field
  • Thank you received: 16
13 years 6 months ago #92717
Whas is the difference between the parameters
Macsimum length
and
Size
in the custom fields creation process?
13 years 6 months ago #92828
Maximum length is used for the number of character that the user can enter in the custom fields with the type text or textarea.
And size is for the dropdowns, it set the number of line to display.
