weight calculator/show weight of products in cart
13 years 10 months ago #69145
On my site it is important that customers can check the weight of their shopping cart for shipping costs are dependent on weight. Is there a way you can display the current weight of the products in their cart?
price of delivery will vary depending on weight so its crucial that the weight is displayed.
Can anyone advise?
Many Thanks
  • Thank you received: 403
13 years 10 months ago #69152
Hi there,
You can display each product weight by adding this:
echo $row->product_weight;
in the file cart.php (components\views\checkout\tmpl) to display the weight where you want in the product table (for example near to <?php echo $row->product_name; ?> )
If you need the total weight just ask me, I'll give you few more lines of code to do so.
13 years 10 months ago #69203
many thanks for your reply, would it be possible for you to give me the code to display the total weight in the cart.
many thanks
13 years 10 months ago #69204
would it also be possible that when a product is added to the cart the current weight is shown similar to showing the current total price. the idea is that a customer will know how much their shopping weighs as each weight is charged at different rates
many thanks
  • Thank you received: 14191
13 years 10 months ago #69401
You can display the weight of the cart like that:
$cartClass = hikashop_get('class.cart');
$cart = $cartClass->loadFullCart(true);
echo $cart->weight;
13 years 10 months ago #69531
which file do i need to amend for above code?
13 years 10 months ago #69623
can someone let me know which file i need to edit to insert above code and where the code goes in the file? ive been waiting nearly 2 days now for the answer
thanks
13 years 10 months ago #69715
You didn't wait 2 days but 1 day.
You can add it in the same file as Eliot told you already:
If you're unsure, add it at the end of the file.
The following user(s) said Thank You: itye2012
13 years 10 months ago #69825
i tried adding those lines but nothing happened..can you help?
13 years 10 months ago #69827
got it working now to show total weight but can you advise how i can add a label to it as it currently only shows a number, I also need to add a label and enter the weight measurement eg KG or G?
Thanks for your efforts
13 years 10 months ago #69928
After the code I gave, you can just write your main weight unit:
echo "kg";
13 years 10 months ago #69974
many thanks for the help, the weight works great on checkout. Any possibility the current total weight can also be displayed in the cart? I mean not just on checkout but on the cart as the user is shopping
13 years 10 months ago #70120
For the cart module, it's the file 'cart' of the view "product" that you need to modify. The code to add is the same.
13 years 10 months ago #70123
many thanks, Ill try that
13 years 10 months ago #70644
sorry not sure of which exact file you mean can you advise the path and file name?
Many Thanks
13 years 10 months ago #70781
It's the file 'cart' of the view "product" that you need to modify. You can edit it via the menu Display->Views.
13 years 10 months ago #72046
im still not clear on which file to edit sorry, can you advise ? I need to know how to edit? ie is it through ftp or via back end?
13 years 10 months ago #72337
It's in the backend.
When you are in HikaShop, go in the menu Display->Views and search for the file 'cart' of the view "product"
13 years 8 months ago #83547
since i upgraded this is not working for me anymore can you help
i need to display the current total weight in the cart and on checkout
thanks
13 years 8 months ago #83550
Is the code that Nicolas and Eliot gave you still in the file 'cart' of the view "product" ?
Time to create page: 0.114 seconds
